Hi, I am trying to populate a combobox with the field names of a polygon feature class selected by the user from a GxDialog.Here is the code so far, I can't figure out how to get from GxObject to the field names.ThanksPrivate Sub btnCatch_Click()
'Allow the user to select the catchments feature class
Dim pGxDialog As IGxDialog
Set pGxDialog = New GxDialog
pGxDialog.Title = "Select Catchments Feature Class"
pGxDialog.ButtonCaption = "Select"
pGxDialog.AllowMultiSelect = False
pGxDialog.StartingLocation = "Catalog"
Dim pGxFilter As IGxObjectFilter
Set pGxFilter = New GxFilterPolygonFeatureClasses
Set pGxDialog.ObjectFilter = pGxFilter
Dim pLayerFiles As IEnumGxObject
pGxDialog.DoModalOpen 0, pLayerFiles
Dim pLayerFile As IGxObject
Set pLayerFile = pLayerFiles.Next
'Display the name of the selected feature class in the text box
txtboxSelectedFC.Text = pLayerFile.Name
'Populate combobox with the field names from that feature class
Dim pGxFile As IGxFile
Set pGxFile = New GxFile
pGxFile.Path = pLayerFile.FullName
Dim pGxLayer As IGxLayer
End Sub
