On my Hub site, I would like to create a simple table as described in this Hub Blog post. But when I add the table to the Text card as described the table format/edit tool does not appear. As it is now, after I add the table, the only thing I can do it add text to it using the text format tools that appear at the top of the text card. I can't adjust the size of the cells or change the color within the cells unless I use code.
Is the WYSIWYG (what you see is what you get) table tool as described by Klara Schmitt in this document the only tool available for tables?
Thank you
