I have set up the Oracle 64 bit client and added new database connections in ArcGIS Pro to our Oracle database but when I import an MXD my features with Oracle SDE connections all have broken links. It sort of makes sense because the Oracle SDE connection properties in the MXD are different than what is required in ArcGIS Pro but is there a way to fix this or automate resourcing? I would like to be able to import an MXD into ArcGIS Pro and not have broken SDE connections, any suggestions?
Major Note: This is historic projects still using SDE (not direct connections to the database)
