I use ArcGIS JSAPI directly from js.arcgis.com. I more or less randomly get following error when trying to load a map into a MapView from portal or when creating a map from scratch. Am I missing some configuration or something like that? Any ideas? Maybe some availability issue (for me it doesn't look like one) as it works often OK after I load the same map after the error.
The JS code runs in IE, by the way. There is no other option as IE is in this case embedded into a native desktop application and changing it is not an option. However, it doesn't look like browser issue either...
Should I after all use local copy of the API? If so are there any instructions how to do that?
Thanks!
Exception was thrown at line 461, column 236 in https://js.arcgis.com/4.12/
0x800a138f - JavaScript runtime error: Unable to get property 'httpsDomains' of undefined or null reference
Exception was thrown at line 188, column 29 in https://js.arcgis.com/4.12/
Exception was thrown at line 188, column 120 in https://js.arcgis.com/4.12/
Exception was thrown at line 1503, column 211 in https://js.arcgis.com/4.12/
0x800a138f - JavaScript runtime error: Unable to get property 'loaderUrl' of undefined or null reference
