I searched for an answer about this issue but could not find..I upgraded the SDK to 10.1.1 and now graphics that I add to the graphics layer do not show up. I am copy pasting my code below. I removed [graphicsLayer dataChanged] method call since it is removed with the new SDK.============ NSString *imageName = @Orange.png; // Creates a custom marker symbol with the picture AGSPictureMarkerSymbol *myMarkerSymbol = [AGSPictureMarkerSymbol pictureMarkerSymbolWithImageNamed:imageName]; // Gets the size for the node float diameter = 50.0; myMarkerSymbol.size = CGSizeMake( diameter, diameter ); // Converts latitude and longitude values to mercator double num = longtitude * 0.017453292519943295; double x = 6378137.0 * num; double a = latitude * 0.017453292519943295; double mercatorX = x; double mercatorY = 3189068.5 * log((1.0 + sin(a))/(1.0 - sin(a))); //Create an AGSPoint (which inherits from AGSGeometry) that //defines where the Graphic will be drawn AGSPoint* myMarkerPoint = [AGSPoint pointWithX:mercatorX y:mercatorY spatialReference:self.mapView.spatialReference]; //NodeInfoTemplate handles what needs to be written in the callout window NodeInfoTemplate *template = [[NodeInfoTemplate alloc] init]; //Create the Graphic, using the symbol and geometry created earlier AGSGraphic* myGraphic =[AGSGraphic graphicWithGeometry:myMarkerPoint symbol:myMarkerSymbol attributes:nodeDict infoTemplateDelegate:template]; //Add the graphic to the Graphics layer [self.graphicsLayer addGraphic:myGraphic];
============Note that I removed the following line since dataChanged method is removed with the new SDK.[self.graphicsLayer dataChanged];
