Hi folks,I need to get a list of path names for feature classes in a gdb. The gdb is configured something like this:Myfeatures.gdb Feature 1 Dataset[INDENT]fc1, fc2,fc3 [/INDENT] Feature 2 Dataset[INDENT]fc1, fc2,fc3 [/INDENT] Feature 3 Dataset[INDENT]fc1, fc2,fc3 [/INDENT]etc. I am having trouble getting right down to the FC for a path. I tried using the os.path.join function but it doesn't seem to like lists and an input. This is what I have so far for code. import arcpy import os # Set the current workspace gdbInput = "Q:\PIR\GIS\Brett\GDB Import Tool\Test Data\PIR_MR98copy.gdb" gdbOutput = "Q:\PIR\GIS\Brett\GDB Import Tool\Test Data\EmptyGisDeliverables_v14.gdb" arcpy.env.workspace = gdbInput # Create list of datasets in input gdb dsInput = arcpy.ListDatasets() #print dsInput #Create list of fc in ds for ds in dsInput: fcInput = arcpy.ListFeatureClasses(feature_dataset=ds) print fcInput
This is what I get for results from previous code:[u'AppraisalPoint'] [u'BlockHubs', u'BlockPolygon'] [u'RoadLine', u'RoadCrossing', u'RoadNotes', u'RoadHubs'] [u'RiparianLine', u'Riparian_SMZ_Buffer', u'LakeWetland', u'LakeWetlandLine']
Thanks.Brett
