Hello, I am in the process of upgrading my project from ArcGIS 10.2.8-1 to 100.4.0, but I am having an issue inflating the layout. My project uses fragments and at the following line, my application is crashing:
View view = inflater.inflate(R.layout.arcgis_test, null);
I created a test application for my "first map" and it works fine on the same device I am trying to run my full application on. As i mentioned above, my app is using fragments and the test "first map" is not.
My app is built on API 19, which I cannot upgrade at this time, but the requirements for ArcGIS 100 are minimum 19, so I should be good there. The test map was built on API 27.
Other than that, my app is the same as the "first map".
The error I am receiving is below:
android.view.InflateException: Binary XML file line #6: Binary XML file line #6: Error inflating class com.esri.arcgisruntime.mapping.view.MapView
E/art: No implementation found for void com.esri.arcgisruntime.internal.jni.CoreArcGISRuntimeEnvironment.nativeSetTempDirectory(java.lang.String) (tried Java_com_esri_arcgisruntime_internal_jni_CoreArcGISRuntimeEnvironment_nativeSetTempDirectory and Java_com_esri_arcgisruntime_internal_jni_CoreArcGISRuntimeEnvironment_nativeSetTempDirectory__Ljava_lang_String_2)
Caused by: java.lang.UnsatisfiedLinkError: No implementation found for void com.esri.arcgisruntime.internal.jni.CoreArcGISRuntimeEnvironment.nativeSetTempDirectory(java.lang.String) (tried Java_com_esri_arcgisruntime_internal_jni_CoreArcGISRuntimeEnvironment_nativeSetTempDirectory and Java_com_esri_arcgisruntime_internal_jni_CoreArcGISRuntimeEnvironment_nativeSetTempDirectory__Ljava_lang_String_2)
Thanks for any help.
