I haven't quite tamped-down this issue, but I'm having trouble piping-in a SQL-sourced, secured layer into my map. Here's the code snippet:
featureLayer = FeatureLayer(this._objLayers.MyLayer.attColl.URL.val, {
mode: FeatureLayer.MODE_ONDEMAND,
infoTemplate: popupTemplate,
outFields: ["field1", "field2", "field3", "field4", "FOOBAR", "field6"]
});I've found that if I remove the column [FOOBAR], it seems to be added to the map without issue. If I add [FOOBAR], the map doesn't load anything at the normal, starting extent. No errors are reported in console - fiddler just shows an open request (no response). If I zoom-in and reduce extent, some features begin to show, but console reports the message:
dojo.io.script error CancelError: Request canceled
"dojo.io.script error"
[functions]: ,
description: "Request canceled",
dojoType: "cancel",
log: undefined,
message: "Request canceled",
response: { },
stack: undefined
}I tried debugging the proxy, but found nothing constructive - my assumption was that there were either unsafe chars, or maybe a length issue with the return. The latter didn't make sense, though, since the proxy should handle large requests.
As a test, I adjusted the data in the SQL back-end and hard-coded a text value maxing-out the column width. This was piped-in without issue, so I'm beginning to think the proxy is rejecting some unsafe chars.
Has anyone had a similar experience? I'm using the latest release version of the proxy from GitHub (1.1.0).
