I'm creating a tool that allows users to create new features based on the graphic returned by a DrawObject. The graphic is added to a featurelayer. Finally, I save the records via an Editor Widget linked to the featurelayer. Graphics returned by the DrawObject in Polygon mode save fine. Graphics returned by buffering the graphic returned by the DrawObject in Line mode also work fine. However, if the DrawObject is set to rectangle, I can not save the new feature created by graphic. I've attached a screenshot of the error message.[ATTACH=CONFIG]14587[/ATTACH]This is the DrawComplete event handler for my DrawObject /// <summary> /// Rectangle_DrawObject DrawComplete event handler /// Adds user drawn rectangle to Projects FeatureLayer /// </summary> /// <param name="sender"></param> /// <param name="args">DrawEventArgs</param> private void Rectangle_DrawObject_DrawComplete(object sender, DrawEventArgs args) { Rectangle_DrawObject.IsEnabled = false; //Ready the graphic Graphic graphic = new Graphic() { Geometry = args.Geometry }; // Input spatial reference for buffer operation defined by first feature of input geometry array graphic.Geometry.SpatialReference = Map.SpatialReference; AddProjectGraphic(graphic); }The AddProjectGraphic method adds the attributes and adds the graphic to the feature layer /// <summary> /// AddProjectGraphic /// Adds graphic to Projects_Edit featurelayer /// </summary> /// <param name="graphic">Graphic to be added</param> private void AddProjectGraphic(Graphic graphic) { // Retrieve the Projects featurelayer from the application FeatureLayer projects = Map.Layers["Projects_Edit"] as FeatureLayer; // add attributes to the graphic // loop through the field list foreach (var field in projects.LayerInfo.Fields) { // only add fields that are editable and set to null if (field.Editable) { graphic.Attributes[field.Name] = null; } } // end loop // Add the buffered line graphic to the featurelayer if (projects != null) { projects.Graphics.Add(graphic); // turn off datagrid/turn on dataform DocumentFeatureDataGrid.Visibility = Visibility.Collapsed; DocumentFeatureDataForm.Visibility = Visibility.Visible; // set the data forms source to new graphic DocumentFeatureDataForm.GraphicSource = graphic; } }I've used Fiddler to inspect what was being sent to the server when saving the new features.Here is the message sent when trying to save a rectangle...[{,"attributes":{"BARCODE":null,"BAR_IMAGE":null,"DELETE_POLY":null,"DOCHYPERLINK":null,"PROJECT_NAME":null,"PRINT_DATE":null,"FILENUMBER":null,"SHEET_NUMBER":null,"SHEET_TOTAL":null,"COMMUNITY":null,"AVAILABLE":null,"QC":null,"QCDATE":null,"QCUSER":null}}]Here is the message sent when trying to save a polygon...[{"geometry":{"spatialReference":{"wkt":"PROJCS[\"NAD_1983_StatePlane_Michigan_South_FIPS_2113_IntlFeet\",GEOGCS[\"GCS_North_American_1983\",DATUM[\"D_North_American_1983\",SPHEROID[\"GRS_1980\",6378137.0,298.257222101]],PRIMEM[\"Greenwich\",0.0],UNIT[\"Degree\",0.0174532925199433]],PROJECTION[\"Lambert_Conformal_Conic\"],PARAMETER[\"False_Easting\",13123359.58005249],PARAMETER[\"False_Northing\",0.0],PARAMETER[\"Central_Meridian\",-84.36666666666666],PARAMETER[\"Standard_Parallel_1\",42.1],PARAMETER[\"Standard_Parallel_2\",43.66666666666666],PARAMETER[\"Latitude_Of_Origin\",41.5],UNIT[\"Foot\",0.3048]]"},"rings":[[[12761546.5763327,543598.139940832],[12761922.406962,541437.113822478],[12759573.465529,541437.113822478],[12759479.5078716,544161.885884751],[12760419.0844448,542752.521024954],[12761546.5763327,543598.139940832]]]},"attributes":{"BARCODE":"testpolygonforfiddler","BAR_IMAGE":null,"DELETE_POLY":null,"DOCHYPERLINK":null,"PROJECT_NAME":null,"PRINT_DATE":null,"FILENUMBER":null,"SHEET_NUMBER":null,"SHEET_TOTAL":null,"COMMUNITY":null,"AVAILABLE":null,"QC":null,"QCDATE":null,"QCUSER":null}}]
When I debug the program and step through each line of code, the geometry is present in the feature up until I save.Perhaps I've found a bug, but there's no reason I can see that this should fail.Anyone have any suggestions?Craig
