I have created a PMF file with two hyperlinked layers – one works perfectly, the other does not. These are relative links that should point to the same folder structure. The ones that work show in the mouseover as “Folder\Filename.ext”; the ones that don’t work show as “#Folder\Filename.ext#”.
In the MXD the hyperlink addresses are entered exactly the same way in hyperlink-enabled fields. I deleted the hyperlink base in the MXD before publishing and copied the hyperlinked documents into the pmf folder of the package along with the PMF. The hyperlinks from one layer are able to launch from this location, but the hyperlinks from the other are not. I am hoping someone can tell me the meaning of the added “#”s.
