Multiple Charts In Info Window
First off thank you in advance for any help you can provide!!!
I am trying to have multiple charts display in an info window. I am able to have one tab with text, another tab with a chart, and a couple more tabs but the charts will not display. Below is the code I have for 3 tabs with only one of the two charts showing. I have tested the code and if I remove the code for the first chart the second chart will display.
//make a tab container
var tc = new dijit.layout.TabContainer({
style: "width:100%;height:100%;"
}, dojo.create("div"));
//display attribute information
var cp1 = new dijit.layout.ContentPane({
title: "Tract Details",
content: "<a target='_blank' <br />Average Income: " + graphic.attributes.MeanInc + "<br />Average Household Size: " + graphic.attributes.AvgHouseho + "<br />Average Age: " + graphic.attributes.MedianAge
//display a dojo pie chart for the tabs
var cp2 = new dijit.layout.ContentPane({
title: "Race"
var cp3 = new dijit.layout.ContentPane({
title: "Gender"
tc.addChild(cp1);
tc.addChild(cp2);
tc.addChild(cp3);
//create the chart that will display in the second tab
var c = dojo.create("div", {
}, dojo.create('div'));
var chart = new dojox.charting.Chart2D(c);
dojo.addClass(chart, 'chart');
//apply a color theme to the chart
chart.setTheme(dojo.getObject("dojox.charting.themes." + theme));
chart.addPlot("default", {
type: "Pie",
radius: 70,
htmlLabels: true
dojo.connect(tc,'selectChild',function(tabItem){
if(tabItem.title === "Race"){
chart.resize(180,180);
var White = dojo.number.round(graphic.attributes.PercWhite);
var Hispanic = dojo.number.round(graphic.attributes.PercHisp);
var Black = dojo.number.round(graphic.attributes.PercBlack);
var Asian = dojo.number.round(graphic.attributes.PercAsian);
chart.addSeries("Race", [{
y: White,
tooltip: White,
text: 'White'
y: Hispanic,
tooltip: Hispanic,
text: 'Hispanic'
y: Black,
tooltip: Black,
text: 'Black'
y: Asian,
tooltip: Asian,
text: 'Asian'
//highlight the chart and display tooltips when you mouse over a slice.
new dojox.charting.action2d.Highlight(chart, "default");
new dojox.charting.action2d.Tooltip(chart, "default");
new dojox.charting.action2d.MoveSlice(chart, "default");
cp2.set('content', chart.node);
return tc.domNode;
//create the chart that will display in the third tab
var c3 = dojo.create("div", {
var chart2 = new dojox.charting.Chart2D(c3);
dojo.addClass(chart2, 'chart');
chart2.setTheme(dojo.getObject("dojox.charting.themes." + theme));
chart2.addPlot("default", {
type: "Pie",
radius: 70,
htmlLabels: true
if(tabItem.title === "Gender"){
chart2.resize(180,180);
var Male = dojo.number.round(graphic.attributes.PercMale);
var Female = dojo.number.round(graphic.attributes.PercFemale);
chart2.addSeries("People", [{
y: Male,
tooltip: Male,
text: 'Male'
y: Female,
tooltip: Female,
text: 'Female'
new dojox.charting.action2d.Highlight(chart2, "default");
new dojox.charting.action2d.Tooltip(chart2, "default");
new dojox.charting.action2d.MoveSlice(chart2, "default");
cp3.set('content', chart2.node);
return tc.domNode;
dojo.ready(init);
