Hello, I am trying to download a map for offline use but am running into trouble with generating the parameters as per this error I get (I have included my code also):
@Override
protected void onCreate(Bundle savedInstanceState) {
super.onCreate(savedInstanceState);
setContentView(R.layout.activity_offline);
// inflate MapView from layout
aMapView = (MapView) findViewById(R.id.mapView);
map = new ArcGISMap(Basemap.Type.LIGHT_GRAY_CANVAS_VECTOR, 48.6596, -113.7870, 9);
aMapView.setMap(map);
// create a graphics overlay and symbol to mark the extent
mGraphicsOverlay = new GraphicsOverlay();
aMapView.getGraphicsOverlays().add(mGraphicsOverlay);
mProgressLayout = (RelativeLayout) findViewById(R.id.progressLayout);
final ProgressBar progressBar = (ProgressBar) findViewById(R.id.taskProgressBar);
mProgressTextView = (TextView) findViewById(R.id.progressTextView);
// get the callout that shows attributes
//aCallout = aMapView.getCallout();
// layer 0, facilities
table0 = new ServiceFeatureTable(getResources().getString(R.string.layer0_url));
final FeatureLayer featureLayer0 = new FeatureLayer(table0);
map.getOperationalLayers().add(featureLayer0);
// layer 1, trails
table1 = new ServiceFeatureTable(getResources().getString(R.string.layer1_url));
final FeatureLayer featureLayer1 = new FeatureLayer(table1);
map.getOperationalLayers().add(featureLayer1);
final GraphicsOverlay graphicsOverlay = new GraphicsOverlay();
aMapView.getGraphicsOverlays().add(graphicsOverlay);
final SimpleLineSymbol boundarySymbol = new SimpleLineSymbol(SimpleLineSymbol.Style.SOLID, Color.RED, 5);
final Button startdownload = (Button) findViewById(R.id.startdownload);
// create a geodatabase sync task
final GeodatabaseSyncTask geodatabaseSyncTask = new GeodatabaseSyncTask(getString(R.string.glacier_sync));
geodatabaseSyncTask.loadAsync();
geodatabaseSyncTask.addDoneLoadingListener(() -> {
// generate the geodatabase sync task
startdownload.setOnClickListener(new View.OnClickListener() {
@Override public void onClick(View v) {
// show the progress layout
progressBar.setProgress(0);
mProgressLayout.setVisibility(View.VISIBLE);
// clear any previous operational layers and graphics if button clicked more than once
map.getOperationalLayers().clear();
graphicsOverlay.getGraphics().clear();
// show the extent used as a graphic
Envelope extent = aMapView.getVisibleArea().getExtent();
Graphic boundary = new Graphic(extent, boundarySymbol);
graphicsOverlay.getGraphics().add(boundary);
// create generate geodatabase parameters for the current extent
final ListenableFuture<GenerateGeodatabaseParameters> defaultParameters = geodatabaseSyncTask
.createDefaultGenerateGeodatabaseParametersAsync(extent);
defaultParameters.addDoneListener(new Runnable() {
@Override public void run() {
try {
// set parameters and don't include attachments
******* GenerateGeodatabaseParameters parameters = defaultParameters.get();
// set the sync model to per layer
parameters.setSyncModel(SyncModel.PER_LAYER);
// define the layers and features to include
int facilities = 1;
int trails = 3;
// Clear and re-create the layer options
parameters.getLayerOptions().clear();
parameters.getLayerOptions().add(new GenerateLayerOption(facilities));
parameters.getLayerOptions().add(new GenerateLayerOption(trails));
parameters.setReturnAttachments(false);
// define the local path where the geodatabase will be stored
final String localGeodatabasePath =
getCacheDir().toString() + File.separator + getString(R.string.file_name);
// create and start the job
final GenerateGeodatabaseJob generateGeodatabaseJob = geodatabaseSyncTask
.generateGeodatabaseAsync(parameters, localGeodatabasePath);
generateGeodatabaseJob.start();
mProgressTextView.setText(getString(R.string.progress_started));
// update progress
generateGeodatabaseJob.addProgressChangedListener(() -> {
progressBar.setProgress(generateGeodatabaseJob.getProgress());
mProgressTextView.setText(getString(R.string.progress_fetching));
// get geodatabase when done
generateGeodatabaseJob.addJobDoneListener(new Runnable() {
mProgressLayout.setVisibility(View.INVISIBLE);
if (generateGeodatabaseJob.getStatus() == Job.Status.SUCCEEDED) {
final Geodatabase geodatabase = generateGeodatabaseJob.getResult();
geodatabase.loadAsync();
geodatabase.addDoneLoadingListener(new Runnable() {
if (geodatabase.getLoadStatus() == LoadStatus.LOADED) {
mProgressTextView.setText(getString(R.string.progress_done));
for (GeodatabaseFeatureTable geodatabaseFeatureTable : geodatabase
.getGeodatabaseFeatureTables()) {
geodatabaseFeatureTable.loadAsync();
map.getOperationalLayers().add(new FeatureLayer(geodatabaseFeatureTable));
startdownload.setVisibility(View.GONE);
Log.i(TAG, "Local geodatabase stored at: " + localGeodatabasePath);
} else {
Log.e(TAG, "Error loading geodatabase: " + geodatabase.getLoadError().getMessage());
// unregister since we're not syncing
ListenableFuture unregisterGeodatabase = geodatabaseSyncTask
.unregisterGeodatabaseAsync(geodatabase);
unregisterGeodatabase.addDoneListener(new Runnable() {
Log.i(TAG, "Geodatabase unregistered since we wont be editing it in this sample.");
Toast.makeText(OfflineActivity.this,
"Geodatabase unregistered since we wont be editing it in this sample.",
Toast.LENGTH_LONG).show();
} else if (generateGeodatabaseJob.getError() != null) {
Log.e(TAG, "Error generating geodatabase: " + generateGeodatabaseJob.getError().getMessage());
} else {
Log.e(TAG, "Unknown Error generating geodatabase");
} catch (InterruptedException | ExecutionException e) {
Log.e(TAG, "Error generating geodatabase parameters : " + e.getMessage());
E/CRGdb: Error generating geodatabase parameters : com.esri.arcgisruntime.ArcGISRuntimeException: Invalid response
*******I have commented out portions of the code because it was returning this error each time and I wanted to know when it began (apparently it was after this line:
