I am trying to build a table that simply has Fnode, Tnode and StreetName but cannot get accurate data.
With a StreetCenterline featureclass, I used Feature Vertices to Points - BOTH_ENDS to create a Nodes featureclass. Then I used both the Centerlines and the Nodes to create a coverage. The problem is that the Node table picks a Centerline# that may or may not be accurate (since multiple centerlines can come into a node). The Centerline table of the coverage only has FNode and TNode with a FID that may or may not be in the Node table.
I am looking for a more accurate way of doing this. I do not need to build a Network Dataset or a Geometric Network, I just need to know the right StreetName between each FNode and Tnode.
