I have a dictionary in the form of:
year2018 <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">{</SPAN><SPAN class="string token">'jan18'</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">2018</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">'feb18'</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="number token">2</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">2018</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">'mar18'</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="number token">3</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">2018</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'apr18'</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="number token">4</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">2018</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">'may18'</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="number token">5</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">2018</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">'jun18'</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="number token">6</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">2018</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">'jul18'</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="number token">7</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">2018</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">'aug18'</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="number token">8</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">2018</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">'sept18'</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="number token">9</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">2018</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">'oct18'</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="number token">10</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">2018</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">'nov18'</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="number token">11</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">2018</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">'dec18'</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="number token">12</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">2018</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>I have a data table where each record has Month field and a Year field. I would like to iterate through my dictionary so that while key = jan18, I select records from my table where Month = 1 and Year = 2018, and then export those records to a stand-alone table called jan18: then move on to key = feb18, etc etc. I've tried a couple different approaches, but still not quite getting what I want. Any suggestions are appreciated. (Using a dictionary is cool, but I'm open to all suggestions...)
