Hello,I have a identify function that is working when I select one feature on the map at a time. The results are then sent to a datagrid. I would like the option to be able to select multiple features at a time by drawing a rectangle on the map. Ideally, the user could chose which layer to view data for through a window prompt. Is this possible or does Identify only work on one feature at a time?Thanks so much for any advice!!
function doIdentify(evt) {
map.infoWindow.hide();
identifyParams.layerIds = [0,2];
var measureMode = dojo.query(".esriButton .dijitButtonNode").some(function(node, index, arr){
if(node.childNodes[0].checked){
//at least one of the measure tools is active so disable identify
return true;
if(! measureMode){
map.graphics.clear();
identifyParams.geometry = evt.mapPoint;
identifyParams.mapExtent = map.extent;
identifyTask.execute(identifyParams,showResults);
function showResults(results) {
var symbol = new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([98,194,204]), 2), new dojo.Color([98,94,204,0.8]));
var idLayer;
var highlightSymbol = new esri.symbol.SimpleMarkerSymbol().setColor(new dojo.Color([25,50,225,0.3]));
//create array of attributes
var items = dojo.map(results,function(result){
var graphic = result.feature;
graphic.setSymbol(symbol);
map.graphics.add(graphic);
//Highlight selected feature
graphic.setSymbol(highlightSymbol);
return result.feature.attributes;
//Create data object to be used in store
if (results[0].layerName == 'Control Points') {
showPointNameGrid();
searchType = "selControl";
var data = {
identifier: 'POINT_NAME', //This field needs to have unique values
label: 'POINT_NAME', //Name field for display. Not pertinent to a grid but may be used elsewhere.
items: items
//Create data store and bind to grid.
store = new dojo.data.ItemFileReadStore({ data:data });
var grid = dijit.byId('grid4');
grid.setStore(store);
} else if (results[0].layerName == 'surveys') {
showSurveysNameGrid();
searchType = "selSurvey";
var data = {
identifier: 'DOCUMENT_N', //This field needs to have unique values
label: 'DOCUMENT_N', //Name field for display. Not pertinent to a grid but may be used elsewhere.
items: items
var grid = dijit.byId('grid5');
} else if (results[0].layerName == 'Cities') {
showCityGrid();
var data = {
identifier: 'CITY', //This field needs to have unique values
label: 'CITY', //Name field for display. Not pertinent to a grid but may be used elsewhere.
items: items
var grid = dijit.byId('grid2');
