I'm having issues submitting string input to a GP Service. Using AGS 10.4.1. The service has one input parameter of string type, but every time I run the service it runs it with the default string input rather than the value I am passing to the GP Service. How do you get it to accept your new string input? I'm calling the service from Javascript API 3.23. I upload a zip file and accept string input from a form element:
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>form</SPAN> <SPAN class="attr-name token">id</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>uploadForm<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token">method</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>post<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token">enctype</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>multipart/form-data<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN>
State Abbreviation: <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>input</SPAN> <SPAN class="attr-name token">type</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>text<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token">name</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>stateAbbrev<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token">id</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>stateAbbrev<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN><SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>br</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>label</SPAN> <SPAN class="attr-name token">class</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>custom-file-upload<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN><SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>input</SPAN> <SPAN class="attr-name token">type</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>file<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token">name</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>file<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token">id</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>dataUpload<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">/></SPAN></SPAN>File Upload<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>label</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>input</SPAN> <SPAN class="attr-name token">type</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>button<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token">value</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>Upload<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token">id</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>upload<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">/></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>form</SPAN><SPAN class="punctuation token">></SPAN></SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Then, after clicking the upload button, it gets to this function:
<SPAN class="keyword token">function</SPAN> <SPAN class="token function">uploadSucceeded</SPAN><SPAN class="punctuation token">(</SPAN>response<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> itemID <SPAN class="operator token">=</SPAN> response<SPAN class="punctuation token">[</SPAN><SPAN class="string token">"item"</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>itemID<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> dataFile <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">esri<SPAN class="punctuation token">.</SPAN>tasks<SPAN class="punctuation token">.</SPAN>DataFile</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
dataFile<SPAN class="punctuation token">.</SPAN>itemID <SPAN class="operator token">=</SPAN> itemID<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> stateAbbrv <SPAN class="operator token">=</SPAN> document<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getElementById</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"stateAbbrev"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>value<SPAN class="punctuation token">;</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"File upload successful"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> params <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">{</SPAN><SPAN class="string token">"Input_Zip_File"</SPAN><SPAN class="punctuation token">:</SPAN> dataFile<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"State_Abbreviation"</SPAN><SPAN class="punctuation token">:</SPAN> stateAbbrv<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">;</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'Input parameters: '</SPAN><SPAN class="operator token">+</SPAN> dojo<SPAN class="punctuation token">.</SPAN><SPAN class="token function">toJson</SPAN><SPAN class="punctuation token">(</SPAN>params<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
gp<SPAN class="punctuation token">.</SPAN><SPAN class="token function">submitJob</SPAN><SPAN class="punctuation token">(</SPAN>params<SPAN class="punctuation token">,</SPAN> gpJobComplete<SPAN class="punctuation token">,</SPAN> gpJobStatus<SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>error<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">error</SPAN><SPAN class="punctuation token">(</SPAN>error<SPAN class="punctuation token">.</SPAN>jobStatus <SPAN class="operator token">+</SPAN> <SPAN class="string token">'('</SPAN> <SPAN class="operator token">+</SPAN> error<SPAN class="punctuation token">.</SPAN>jobId <SPAN class="operator token">+</SPAN> <SPAN class="string token">'):'</SPAN> <SPAN class="operator token">+</SPAN> dojo<SPAN class="punctuation token">.</SPAN><SPAN class="token function">toJson</SPAN><SPAN class="punctuation token">(</SPAN>error<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>In the function above, the line
<SPAN class="keyword token">var</SPAN> params <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">{</SPAN><SPAN class="string token">"Input_Zip_File"</SPAN><SPAN class="punctuation token">:</SPAN> dataFile<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"State_Abbreviation"</SPAN><SPAN class="punctuation token">:</SPAN> stateAbbrv<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN></SPAN>sets the State_Abbreviation parameter to the new user-supplied string input. This prints out correctly in the browser console:
Input parameters: {"Input_Zip_File":{"itemID":"i0cd7358b-f7d4-4238-8d10-4bbdc624e895"},"State_Abbreviation":"AR"}<SPAN class="line-numbers-rows"><SPAN></SPAN></SPAN>But, using messages in the browser console, I can see it's running the GP Service using the default string input of "TN" which is the value the GP Service was published with (thus it becomes the default value). I need to somehow override that value, but I can't figure out how?
