Good day everyone. I am running this code in ArcPro and receive the following error:
It tells me that my input feature does not exist or is not supported. I have ran this script in python 2.7 and it all works fine. Thank all of you in advance.
<SPAN class="comment token">#Import ArcPy modules</SPAN>
<SPAN class="keyword token">import</SPAN> arcpy
<SPAN class="keyword token">from</SPAN> arcpy <SPAN class="keyword token">import</SPAN> env
<SPAN class="comment token"># Set the workspace</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>env<SPAN class="punctuation token">.</SPAN>workspace <SPAN class="operator token">=</SPAN> <SPAN class="string token">"Database Connections/ADMIN Edit.sde/CustomerServiceFeatures"</SPAN>
ArcSDE <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>env<SPAN class="punctuation token">.</SPAN>workspace
env<SPAN class="punctuation token">.</SPAN>overwriteOutput <SPAN class="operator token">=</SPAN> <SPAN class="token boolean">True</SPAN>
<SPAN class="comment token"># Set local variables</SPAN>
inFeatures <SPAN class="operator token">=</SPAN> <SPAN class="string token">"GPS_Meter_CustomerServiceFieldCrew"</SPAN>
outputLocation <SPAN class="operator token">=</SPAN> <SPAN class="string token">"X:/Planning/GIS/Meter GPS/GPS Meter Collection/Customer Service/GPS CC&B Joins"</SPAN>
outputFolderName <SPAN class="operator token">=</SPAN> <SPAN class="string token">"00_00_19"</SPAN>
outputFolderLocation <SPAN class="operator token">=</SPAN> <SPAN class="string token">"X:/Planning/GIS/Meter GPS/GPS Meter Collection/Customer Service/GPS CC&B Joins/00_00_19"</SPAN>
outputDatabase <SPAN class="operator token">=</SPAN> <SPAN class="string token">"CC&B iPad Meters.gdb"</SPAN>
outputDatabaseLocation <SPAN class="operator token">=</SPAN> <SPAN class="string token">"X:/Planning/GIS/Meter GPS/GPS Meter Collection/Customer Service/GPS CC&B Joins/00_00_19/CC&B iPad Meters.gdb"</SPAN>
outputFeatureClass <SPAN class="operator token">=</SPAN> <SPAN class="string token">"GPS_Meter_CS"</SPAN>
expression <SPAN class="operator token">=</SPAN> <SPAN class="string token">"SERVICEPOINTID IS NULL"</SPAN>
<SPAN class="comment token"># Create folder</SPAN>
<SPAN class="comment token">## UPDATE outputFolderName, outputFolderLocation, AND outputDatabaseLocation</SPAN>
<SPAN class="comment token">## VARIABLE EVERYTIME THIS PROCESS RUNS WITH CURRENT DATE (MM_DD_YY).</SPAN>
<SPAN class="keyword token">print</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Creating folder."</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>CreateFolder_management<SPAN class="punctuation token">(</SPAN>outputLocation<SPAN class="punctuation token">,</SPAN> outputFolderName<SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token"># Create new .gdb</SPAN>
<SPAN class="keyword token">print</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Creating geodatabase."</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>CreateFileGDB_management<SPAN class="punctuation token">(</SPAN>outputFolderLocation<SPAN class="punctuation token">,</SPAN> outputDatabase<SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token"># Allow database to accept attachments.</SPAN>
<SPAN class="keyword token">print</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'Allowing attachments'</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>env<SPAN class="punctuation token">.</SPAN>maintainAttachments <SPAN class="operator token">=</SPAN> <SPAN class="token boolean">True</SPAN>
<SPAN class="comment token"># Export feature class geodatabase</SPAN>
<SPAN class="keyword token">print</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Exporting feature class to feature class"</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>FeatureClassToFeatureClass_conversion<SPAN class="punctuation token">(</SPAN>inFeatures<SPAN class="punctuation token">,</SPAN> outputDatabaseLocation<SPAN class="punctuation token">,</SPAN> outputFeatureClass<SPAN class="punctuation token">,</SPAN> expression<SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token"># Finish</SPAN>
<SPAN class="keyword token">print</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Done"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
