My scenario is as below .
1. I am opening an MXD from a standalone exe file.This is fine, the MXD is getting opened successfully.
2. I have developed an ArcMap extension and it it's Startup event, I want to call the the VBA macro inside the MXD.
3. The problem is here, I get an error "Error running VBA code : Error in macro"
4. The macro works fine manually, I means I open the MXD and run the macro manually, it runs fine.
Code to tun the macro is as below:
private bool RunMyMacro(IApplication pApplication)
try
IMxDocument pMxDoc = pApplication.Document as IMxDocument;
IMapDocument pMapDoc = pMxDoc as IMapDocument;
//check the name of the MXD. IF it is what we wantm run the macro
if (String.IsNullOrEmpty(pMapDoc.DocumentFilename) == false)
if (pMapDoc.DocumentFilename.Contains("MyMXDName"))
//run the macro
IVbaApplication pVBAApps = pApplication as IVbaApplication;
pVBAApps.RunVBAMacro("Project", "ThisDocument", "Trace_Transformers_LV", null);
return false;
return true;
catch (Exception ex)
string errMsg = ex.Message;
string stkTrace = ex.StackTrace;
return false;
//Code of StartUp event of an extension
public void Startup(ref object initializationData)
IApplication pApps = initializationData as IApplication;
RunMyMacro(pApps);
Earlier, the macro was getting called from the EXE it self and it works fine .However, after running fine for a week or so, it starts throwing an error. To work around this, I'm trying to call the macro from the extension, but it is also not working.Even a simple HelloWorld macro is not getting called from the extension.
I would really appreciate any help on this issue.
S.
