New to ESRI and solutions - Storm Water.
New to most things GIS, except import export shape files. Civil Cad person trying to use ESRI Solutions for small storm water deployment web maps.
I'd like to start off simple by trying to creating a simple map of existing storm water structures (zipped shape file from arcMap)
I'm having issues understanding if I am doing something wrong with my data. I used the ARC Pro create new proj., then I used the share > arc solution deploy, and selected a small storm water deploy to create a folder in my Online account. That created a folder in my online account .done.
Q. Do I create a layer for my existing shape file data in arc pro to use in the SW solutions manhole layer or do I open the new web maps and insert the shape file data there? if I insert from a file using that method, how do I target the imported shape file to the correct layer under the SW solutions. If I use the SW viewer web map, How do you direct the data from the file to be placed on the manhole web map layer? I don't see how I place that data on the correct manhole layer unless I edit and add those location one at a time to a selected layer.
I could not locate anything that walks you thru the complete process of creating an online map, adding data. how the forms are used or connect to the SW solitons. I think they assume the 4 or 5 pages in the help sections define the entire process. For me, I'm completely lost on how to connect all this up, or even get it to a point I can view any of the data using this solution tools. I thought I could use solution package on a project where we plan to just collect the location of manholes in the field. I might have to put that on hold If I can't get this working.
Any help, direction you can provide is welcome.
Thank you
John
