I'm packaging a project with an embedded python toolbox with the intent of sharing it with others via ArcGIS Online. The python tool imports a module and it looks like the path to that module is being incorrectly changed during consolidation.
The path to the imported module as I created it is:
E:\ROW_as_habitat\temp\test_dir
The path after the consolidation(I ran Package Product, uploaded the .ppkx to ArcGIS Online, then open the uploaded .ppkx in ArcGIS Online via the portal) is
C:\Users\DMORRI~1\AppData\Local\Temp\ArcGISProTemp1188\..\test_project_1\p20\test_dir
I would expect the fixed up path to point into the Packages directory, but this is pointing into the temp directory. I do see the module in what I believe is the proper place in under the Packages directory. In any case the import fails when I run the tool from the packaged project.
Here is the tool code as I created it in ArcGIS Pro
<SPAN class="comment token"># -*- coding: utf-8 -*-</SPAN>
<SPAN class="keyword token">import</SPAN> arcpy
<SPAN class="keyword token">class</SPAN> <SPAN class="token class-name">Toolbox</SPAN><SPAN class="punctuation token">(</SPAN>object<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">def</SPAN> <SPAN class="token function">__init__</SPAN><SPAN class="punctuation token">(</SPAN>self<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
self<SPAN class="punctuation token">.</SPAN>label <SPAN class="operator token">=</SPAN> <SPAN class="string token">"Toolbox"</SPAN>
self<SPAN class="punctuation token">.</SPAN>alias <SPAN class="operator token">=</SPAN> <SPAN class="string token">""</SPAN>
self<SPAN class="punctuation token">.</SPAN>tools <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN>Tool<SPAN class="punctuation token">]</SPAN>
<SPAN class="keyword token">class</SPAN> <SPAN class="token class-name">Tool</SPAN><SPAN class="punctuation token">(</SPAN>object<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
self<SPAN class="punctuation token">.</SPAN>label <SPAN class="operator token">=</SPAN> <SPAN class="string token">"Tool"</SPAN>
self<SPAN class="punctuation token">.</SPAN>description <SPAN class="operator token">=</SPAN> <SPAN class="string token">""</SPAN>
self<SPAN class="punctuation token">.</SPAN>canRunInBackground <SPAN class="operator token">=</SPAN> <SPAN class="token boolean">False</SPAN>
<SPAN class="keyword token">def</SPAN> <SPAN class="token function">getParameterInfo</SPAN><SPAN class="punctuation token">(</SPAN>self<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
params <SPAN class="operator token">=</SPAN> None
<SPAN class="keyword token">return</SPAN> params
<SPAN class="keyword token">def</SPAN> <SPAN class="token function">isLicensed</SPAN><SPAN class="punctuation token">(</SPAN>self<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">return</SPAN> <SPAN class="token boolean">True</SPAN>
<SPAN class="keyword token">def</SPAN> <SPAN class="token function">updateParameters</SPAN><SPAN class="punctuation token">(</SPAN>self<SPAN class="punctuation token">,</SPAN> parameters<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">def</SPAN> <SPAN class="token function">updateMessages</SPAN><SPAN class="punctuation token">(</SPAN>self<SPAN class="punctuation token">,</SPAN> parameters<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">def</SPAN> <SPAN class="token function">execute</SPAN><SPAN class="punctuation token">(</SPAN>self<SPAN class="punctuation token">,</SPAN> parameters<SPAN class="punctuation token">,</SPAN> messages<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
test_dir <SPAN class="operator token">=</SPAN> r<SPAN class="string token">'E:\ROW_as_habitat\temp\test_dir'</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>AddMessage<SPAN class="punctuation token">(</SPAN>test_dir<SPAN class="punctuation token">)</SPAN>
sys<SPAN class="punctuation token">.</SPAN>path<SPAN class="punctuation token">.</SPAN>append<SPAN class="punctuation token">(</SPAN>test_dir<SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">import</SPAN> logger <SPAN class="keyword token">as</SPAN> row_logger
arcpy<SPAN class="punctuation token">.</SPAN>AddMessage<SPAN class="punctuation token">(</SPAN>row_logger<SPAN class="punctuation token">.</SPAN>LOG_FILE<SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">return</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>Here is the code after the fixup
<SPAN class="comment token">#</SPAN>
<SPAN class="comment token"># Esri start of added imports</SPAN>
<SPAN class="keyword token">import</SPAN> sys<SPAN class="punctuation token">,</SPAN> os<SPAN class="punctuation token">,</SPAN> arcpy
<SPAN class="comment token"># Esri end of added imports</SPAN>
<SPAN class="comment token"># Esri start of added variables</SPAN>
g_ESRI_variable_1 <SPAN class="operator token">=</SPAN> os<SPAN class="punctuation token">.</SPAN>path<SPAN class="punctuation token">.</SPAN>join<SPAN class="punctuation token">(</SPAN>arcpy<SPAN class="punctuation token">.</SPAN>env<SPAN class="punctuation token">.</SPAN>scriptWorkspace<SPAN class="punctuation token">,</SPAN><SPAN class="string token">'..\\test_project_1\\p20\\test_dir'</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token"># Esri end of added variables</SPAN>
test_dir <SPAN class="operator token">=</SPAN> g_ESRI_variable_1
