I have developed a script that loops through all MXDs in a given directory, stores relative paths and then saves it as ArcGIS 9.x compatible. At firts I thought it was working as expected. But I just opened one of the copied MXDs and it has reset the page layout to portrait 8.5 x 11. The original file was landscape 13 x 8.5.Any idea why it did this and how I could modify the code to insure that the layout information is preserved in the resulting copy?Here is my code:
import arcpy, os
def prinnames(sPath):
folderPath = sPath
for filename in os.listdir(folderPath):
fullpath = os.path.join(folderPath, filename)
if os.path.isfile(fullpath):
basename, extension = os.path.splitext(fullpath)
if extension.lower() == ".mxd":
mxd = arcpy.mapping.MapDocument(fullpath)
print(basename + "v9")
mxd.relativePaths = 'True'
mxd.saveACopy(basename + "v9.mxd","9.0")
else:
prinnames(fullpath)
prinnames('C:\Gareth\cityWork\CAPERMaps')
