Part of my addin is trying to connect to what could be a SDE connection. I'm using WorkspaceFactory.OpenfromFile to connect to the geodatabase, because the connection could be to a file geodatabase, personal geodatabase, or an sde connection. Here's where my error is coming in. When I set the location of my connection file to the absolute location (C:\Users\ ... \ArcCatalog\myGIS.sde), it connects fine. But when I set it to "Database Connections\myGIS.sde", which is the location I get when I use the ArcCatalog dialog to browse to the geodatabase, the connection throws an error.Is there a way to get the file location for the database connection file programmatically? I want to use OpenFromFile because I don't want to handle user names and passwords, and because I can open other geodatabases with the same code.Here's an edited snippet of my code: ' code works when connection = "C:\Users\ ... \ArcCatalog\myGIS.sde" Dim connection as String = "Database Connections\myGIS.sde" Dim myWorkspace as IWorkspace Dim factoryType as Type = Type.GetTypeFromProgID("esriDataSourcesGDB.SdeWorkspaceFactory") Dim myWorkspaceFactory = Ctype(Activator.CreateInstance(factoryType), IWorkspaceFactory) myWorkspace = myWorkspaceFactory.OpenFromFile(connection, 0) ' here is where I get the error.
