Defining Raster Extents using Python Geoprocessing Script
Hello, I'm trying to import and define the extents of raster GeoTIFF images. For some reason, after the update of ArcGIS 10 SP1 I am not able to define extents of these images such that the extents remain in the raster images after I convert them.
I've specified my extents several times through my code, but I don't understand why this doesn't 'take' in the final product.
Any ideas? Thanks for your thoughts in advance... My Python code is posted below.
Katrina
import arcgisscripting, sys, os, shutil, datetime, re, arcpy
gp = arcgisscripting.create()
gp.overwriteoutput = 1
gp.CheckOutExtension("spatial")
gp.AddToolbox("C:/Program Files (x86)/ArcGIS/Desktop10.0/ArcToolbox/Toolboxes/Data Management Tools.tbx")
gp.AddToolbox("C:/Program Files (x86)/ArcGIS/Desktop10.0/ArcToolbox/Toolboxes/Spatial Analyst Tools.tbx")
sourceDirRas = r"G:\modis\updated_example\my_own\albers"
extent = "-1805197.82136111 374274.164059672 1712802.17863889 2569774.16405967"
i = 1
for root, dirs, files in os.walk(sourceDirRas):
for file in files:
if file[-4:] == ".tif":
wholeFile = root + "\\" + file
outFile = root + "\\out\\" + "ms" + str(i)
print file
#Calculate Stats
print "Calculating Stats!"
gp.CalculateStatistics_management(wholeFile, "", "", "")
print "Setting Extent and Define Projection!"
tempEnvironment0 = arcpy.env.extent
arcpy.env.extent = "-1805197.82136111 374274.164059672 1712802.17863889 2569774.16405967"
#gp.Extent = "-1805197.82136111 374274.164059672 1712802.17863889 2569774.16405967"
arcpy.DefineProjection_management(wholeFile, "PROJCS['AEA_North_American_Datum_1983',GEOGCS['GCS_North_American_1983',DATUM['D_North_American_1983',SPHEROID['GRS_1980',6378137.0,298.257222101]],PRIMEM['Greenwich',0.0],UNIT['Degree',0.0174532925199433]],PROJECTION['Albers'],PARAMETER['false_easting',0.0],PARAMETER['false_northing',0.0],PARAMETER['central_meridian',-154.0],PARAMETER['standard_parallel_1',55.0],PARAMETER['standard_parallel_2',65.0],PARAMETER['latitude_of_origin',50.0],UNIT['Meter',1.0]]")
arcpy.env.extent = tempEnvironment0
print "Copy Raster!"
#gp.CopyRaster_management(wholeFile, outFile, "#","0","#","NONE","NONE","#")
arcpy.CopyRaster_management(wholeFile, outFile, "", "", "", "NONE", "NONE", "")
i = i + 1
print "Done!"
