Hi, I have set up a web map containing feature service layers in AGOL which is being used in Collector by our land owner assistance biologists. Presently the biologists are creating property boundaries in ArcMap and adding them to our content prior to field work which can occur on the same day and can be one layer at a time depending on work load. The original idea was to use Collector for tracking but I foresee the editing component with multiple layers added as a potential train wreck. Should I set up a separate map or group with the appropriate privileges for the editing work or should each biologist have their own map in the same group? Our group consists of only our contributors. In the end, there will be a planning layer, and a completed layer after the work has been done, but many changes can occur in the year or two in between. Appreciate your suggestions!
