Hello,I am having an issue binding the Layers object to my Map object. I have looked over a few other posts and try to re-create their fixes but cannot. I do not get an error, I just do not get a map visually displayed. Here are some of my code snippets. Can anyone see what I am doing wrong. Just to be clear:1. My xaml has a map object with a Layers attribute with Binding.2. My xaml.cs Initializes the component and then sets the DataContext3. My ViewModel code, sets the view, runs the CreateMapLayers function that sets the BaseMapLayerService public property (this is the property that the Layers is bound to in xaml). xaml:<UserControl xmlns:sdk="http://schemas.microsoft.com/winfx/2006/xaml/presentation/sdk" x:Class="Geomentum.MediaReach.Modules.Map.View.MapView" xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation" xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml" xmlns:d="http://schemas.microsoft.com/expression/blend/2008" xmlns:mc="http://schemas.openxmlformats.org/markup-compatibility/2006" mc:Ignorable="d" xmlns:esri="http://schemas.esri.com/arcgis/client/2009" xmlns:local="clr-namespace:Geomentum.MediaReach.Modules.Map.View" xmlns:ViewModel="clr-namespace:Geomentum.MediaReach.Modules.Map.ViewModel"> <esri:Map x:Name="MyMap" WrapAround="True" IsLogoVisible="False" Layers="{Binding ViewModel.BaseMapLayerService}" /> </UserControl>xaml.cs:using System; using System.Collections.Generic; using System.Linq; using System.Net; using System.Windows; using System.Windows.Controls; using System.Windows.Documents; using System.Windows.Input; using System.Windows.Media; using System.Windows.Media.Animation; using System.Windows.Shapes; using Geomentum.MediaReach.Modules.Map.ViewModel; namespace Geomentum.MediaReach.Modules.Map.View { public partial class MapView : UserControl, IMapView { public MapView() { InitializeComponent(); } #region IMapView Members public IMapViewModel Model { get { return this.DataContext as MapViewModel; } set { this.DataContext = value; } } #endregion } }MapViewModel.cs:using System; using System.Net; using System.Windows; using System.Windows.Controls; using System.Windows.Documents; using System.Windows.Ink; using System.Windows.Input; using System.Windows.Media; using System.Windows.Media.Animation; using System.Windows.Shapes; using Geomentum.MediaReach.Modules.Map.View; using Microsoft.Practices.Prism.Events; using System.ComponentModel; using System.Collections.Generic; using Geomentum.MediaReach.Infrastructure.Models; namespace Geomentum.MediaReach.Modules.Map.ViewModel { public class MapViewModel : IMapViewModel, INotifyPropertyChanged { private readonly IEventAggregator eventAggregator; private ESRI.ArcGIS.Client.LayerCollection _baseMapLayerService; public IMapView View { get; set; } public MapViewModel(IMapView view, IEventAggregator eventAggregator, MediaReachMap map) { View = view; View.Model = this; BaseMapLayerService = CreateMapLayers(); this.eventAggregator = eventAggregator; } public ESRI.ArcGIS.Client.LayerCollection BaseMapLayerService { get { return this._baseMapLayerService; } set { this._baseMapLayerService = value; OnPropertyChanged("BaseMapLayerService"); } } private ESRI.ArcGIS.Client.LayerCollection CreateMapLayers() { ESRI.ArcGIS.Client.LayerCollection layers = new ESRI.ArcGIS.Client.LayerCollection(); //create the base map layer ESRI.ArcGIS.Client.ArcGISDynamicMapServiceLayer baseLayer = new ESRI.ArcGIS.Client.ArcGISDynamicMapServiceLayer() { ID = "BaseLayer", Url = "http://dg2k8esridev1/ArcGISDevelopment/rest/services/BaseMap/MapServer" }; layers.Add(baseLayer); return layers; } #region INotifyPropertyChanged Members public event PropertyChangedEventHandler PropertyChanged; private void OnPropertyChanged(string propertyName) { PropertyChangedEventHandler handler = this.PropertyChanged; if (handler != null) { handler(this, new PropertyChangedEventArgs(propertyName)); } } #endregion } }
