I am using the below code to draw graphics in the map. Everything works great....
But I want to use those geometries to do spatial queries. I need to call a specific Feature to get the geometry for the query making the Graphic far to general. I am trying to select all the features from X Feature that are within the Geometry Drawn. Noting that there might be other graphics in the map so thats why I am thinking I need to separate them and get them into a Feature that I can reference by itself.
I think I need to push the graphics drawn to a Feature? Not sure how to do this. Once I have the feature I can use its geometry for the query.
Not sure if I am on the right path here...AND unsure how to convert the graphic to a feature so that its geometry can be used in a query....hope someone can help.
// markerSymbol is used for point and multipoint, see http://raphaeljs.com/icons/#talkq for more examples
var DrawmarkerSymbol = new SimpleMarkerSymbol();
DrawmarkerSymbol.setPath("M16,4.938c-7.732,0-14,4.701-14,10.5c0,1.981,0.741,3.833,2.016,5.414L2,25.272l5.613-1.44c2.339,1.316,5.237,2.106,8.387,2.106c7.732,0,14-4.701,14-10.5S23.732,4.938,16,4.938zM16.868,21.375h-1.969v-1.889h1.969V21.375zM16.772,18.094h-1.777l-0.176-8.083h2.113L16.772,18.094z");
DrawmarkerSymbol.setColor(new Color("#00FFFF"));
// http://blogs.esri.com/esri/arcgis/2012/02/03/esri-picture-marker-symbol-generator-for-javascript-developers/
var DrawPicturemarkerSymbol = new esri.symbol.PictureMarkerSymbol({
"angle": 0,
"xoffset": 0,
"yoffset": 12,
"type": "esriPMS",
"url": "http://static.arcgis.com/images/Symbols/Basic/RedStickpin.png",
"contentType": "image/png",
"width": 24,
"height": 24
// lineSymbol used for freehand polyline, polyline and line.
var DrawlineSymbol = new CartographicLineSymbol(
CartographicLineSymbol.STYLE_SOLID,
new Color([255,0,0]), 2,
CartographicLineSymbol.CAP_ROUND,
CartographicLineSymbol.JOIN_MITER, 5
var DrawfillSymbol = new SimpleFillSymbol(
"solid",
new SimpleLineSymbol("solid", new Color([255,0,0]), 2),
new Color([0,128,255,0.25])
function initToolbar() {
tb = new Draw(app.map);
tb.on("draw-end", addGraphic);
// event delegation so a click handler is not
// needed for each individual button
on(dom.byId("infoShapefileCreate"), "click", function(evt) {
if ( evt.target.id === "info" ) {
return;
var tool = evt.target.id.toLowerCase();
app.map.disableMapNavigation();
tb.activate(tool);
function addGraphic(evt) {
//deactivate the toolbar and clear existing graphics
tb.deactivate();
app.map.enableMapNavigation();
// figure out which symbol to use
var symbol;
if ( evt.geometry.type === "point" || evt.geometry.type === "multipoint") {
symbol = DrawPicturemarkerSymbol;
} else if ( evt.geometry.type === "line" || evt.geometry.type === "polyline") {
symbol = DrawlineSymbol;
else {
symbol = DrawfillSymbol;
app.map.graphics.add(new Graphic(evt.geometry, symbol));
