In a python script, I use arcpy.CopyFeatures_management function but it certain situation, some parameters may have a white space such as:
C:\ESRI\City Points_point.shp
Then, when running the script, arcpy.CopyFeatures_management interprets C:\ESRI\City Points_point.shp as 2 parameters because of the white space.
Executing: CopyFeatures 'C:\ESRI\City Points_point.shp' C:\ESRI\City_Points_point.shp # 0 0 0Start Time: Mon Aug 22 16:01:33 2016Failed to execute. Parameters are not valid.
<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN></SPAN>
How would it be possible to arrange the syntax and have 'C:\ESRI\City Points_point.shp' interpreted as just one parameter?
