I want to scale a line graphic on scale event and below is the the code of what i am doing
myEditor.editToolbar.on('scale', function(e) {
var tt = transform(e.graphic.geometry, e.info.scaleX, e.info.scaleY);
tsymbolGraphic.setGeometry(tt);
// and then drawing the tsymbolGraphic on map
///and my transform function
function transform(geometry,scaleX,scaleY)
{ // currently for polyline
var poly = new Polyline(geometry.spatialReference);
var screenPoint,mapPoint;
arrayUtils.forEach(geometry.paths,function(path,i)
poly.paths = [];
arrayUtils.forEach(path,function(pnt,j)
screenPoint = map.toScreen(new Point(pnt[0],pnt[1], geometry.spatialReference));
screenPoint.x = screenPoint.x * scaleX + 5 ;
screenPoint.y = screenPoint.y * scaleY + 5 ;
mapPoint = map.toMap(screenPoint);
poly.paths = [mapPoint.x,mapPoint.y];
return poly;
here is the link of full code https://jsfiddle.net/0fy3v8yr/
