<script type="text/javascript">
dojo.require("dijit.dijit"); // optimize: load dijit layer
dojo.require("dijit.layout.BorderContainer");
dojo.require("dijit.layout.ContentPane");
dojo.require("esri.map");
dojo.require("esri.toolbars.draw");
dojo.require("esri.layers.FeatureLayer");
dojo.require("esri.tasks.query");
dojo.require("dojox.grid.DataGrid");
dojo.require("dojo.data.ItemFileReadStore");
dojo.require("dijit.layout.TabContainer");
var map, toolbar;
var featureLayer;
function init() {
var initExtent = new esri.geometry.Extent({ "xmin": 9773773.173194762, "ymin": -1718113.5089816158, "xmax": 16446419.994375736, "ymax": 1187716.5583068724, "spatialReference": { "wkid": 102100} });
map = new esri.Map("map", {
extent: initExtent
dojo.connect(map, 'onLoad', function (map) {
identifyTask = new esri.tasks.IdentifyTask("http://gisserver/ArcGIS/rest/services/multi/MapServer");
identifyParams = new esri.tasks.IdentifyParameters();
identifyParams.tolerance = 3;
identifyParams.returnGeometry = true;
identifyParams.layerIds = [0, 1, 2];
identifyParams.layerOption = esri.tasks.IdentifyParameters.LAYER_OPTION_ALL;
identifyParams.width = map.width;
identifyParams.height = map.height;
//initialize the toolbar
toolBar = new esri.toolbars.Draw(map);
dojo.connect(toolBar, "onDrawEnd", onDrawEnd);
//resize the map when the browser resizes
dojo.connect(dijit.byId('map'), 'resize', map, map.resize);
var basemapUrl = "http://server.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer";
var basemap = new esri.layers.ArcGISTiledMapServiceLayer(basemapUrl);
var landBaseLayer = new esri.layers.ArcGISDynamicMapServiceLayer("gisserver/ArcGIS/rest/services/multi/MapServer", { opacity: 100 });
map.addLayer(basemap);
map.addLayer(landBaseLayer);
function onDrawEnd(extent) {
toolBar.deactivate();
executeIdentifyTask(extent);
function executeIdentifyTask(geom) {
//clear the graphics layer
map.graphics.clear();
var polygonSymbol = new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID,
new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_DOT,
new dojo.Color([151, 249, 0, .80]), 3),
new dojo.Color([151, 249, 0, 0.45]));
identifyParams.geometry = geom;
identifyParams.mapExtent = map.extent;
identifyTask.execute(identifyParams, function (response) {
var waItems = [];
var weItems = [];
var basItems = [];
dojo.forEach(response, function (result) {
var feature = result.feature;
//add selected feature to graphics layer
feature.setSymbol(polygonSymbol);
map.graphics.add(feature);
if (result.layerName === 'We') {
weItems.push(feature.attributes);
} else if (result.layerName === 'wa') {
waItems.push(feature.attributes);
} else if (result.layerName === 'Bas') {
basItems.push(feature.attributes);
//update the data grid
var waStore = new dojo.data.ItemFileReadStore({ data: { identifier: 'FID', items: waItems} });
gridwa.setStore(waStore);
var weStore = new dojo.data.ItemFileReadStore({ data: { identifier: 'FID', items: weItems} });
gridwe.setStore(weStore);
var basStore = new dojo.data.ItemFileReadStore({ data: { identifier: 'FID', items: basItems} });
gridbas.setStore(basStore);
//show map on load
dojo.addOnLoad(init);
</script> Kelly Hutchins
help create toggle layer for select multiple features
