Hi all,
I am attempting to switch my standard app licensing from Token to OAuth2.
Things is it is not challenging the user for credential and instead throws an Exception.
Esri.ArcGISRuntime.Http.ArcGISWebException: Error code '400' : 'Unable to generate token.'
'username' must be specified.
'password' must be specified.
I should say that It works fine with the token.
Here is what I do.
First set up our challenge handler
// setup our sign challenge handler
var signInChallengeHandler = new Esri.ArcGISRuntime.Toolkit.Security.SignInChallengeHandler()
AllowSaveCredentials = true,
CredentialSaveOption = Esri.ArcGISRuntime.Toolkit.Controls.CredentialSaveOption.Unselected
Esri.ArcGISRuntime.Security.IdentityManager.Current.ChallengeHandler = signInChallengeHandler;
Esri.ArcGISRuntime.Security.IdentityManager.Current.OAuthAuthorizeHandler =
new Esri.ArcGISRuntime.Toolkit.Security.OAuthAuthorizeHandler();
// code for basic license....
Second register the server
var serverInfo = new ServerInfo()
ServerUri = portalServerUrl,
OAuthClientInfo = new OAuthClientInfo()
ClientId = "xyz",
ClientSecret = "xyz"
TokenAuthenticationType = TokenAuthenticationType.OAuthAuthorizationCode
Esri.ArcGISRuntime.Security.IdentityManager.Current.RegisterServer(serverInfo);
Finally request for the credentials
var credRequest = new CredentialRequestInfo()
ServiceUri = portalServerUrl,
var cred = await IdentityManager.Current.GetCredentialAsync(credRequest, true);
If instead I use
var cred = await IdentityManager.Current.GenerateCredentialAsync(portalServerUrl, "user", "pass");
I get Esri.ArcGISRuntime.Http.ArcGISWebException: Error code '400' : 'client_id not specified'
What am I missing here ?
