I have a series of graphics that get added to a single graphics layer when a user toggles on a switch. There are different toggles for each graphic (they're routes to bus lines) but all route graphics are being added to the same graphics layer. When a user toggles off a certain route, I want the route to be removed from the graphics layer, but keep the other routes on the graphics layers if they're toggled on. I have assigned the graphic being added a unique ID, however, using graphicsLayerName.remove(graphicID) isn't working for me.
<SPAN class="comment token">//create graphic layer</SPAN>
app<SPAN class="punctuation token">.</SPAN>routesGraphicsLayer <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">GraphicsLayer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
id<SPAN class="punctuation token">:</SPAN><SPAN class="string token">'routesGraphicsLayer'</SPAN>
<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token">//Add graphics layer</SPAN>
app<SPAN class="punctuation token">.</SPAN>map<SPAN class="punctuation token">.</SPAN><SPAN class="token function">addLayer</SPAN><SPAN class="punctuation token">(</SPAN>app<SPAN class="punctuation token">.</SPAN>routesGraphicsLayer<SPAN class="punctuation token">)</SPAN>
app<SPAN class="punctuation token">.</SPAN>routesGraphicsLayer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">hide</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="comment token">//will get shown when toggled on</SPAN>
<SPAN class="comment token">//Create unique variable names for graphic IDs</SPAN>
<SPAN class="keyword token">var</SPAN> redRoute<SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">//When Toggled ON:</SPAN>
app<SPAN class="punctuation token">.</SPAN>handleLayerVis <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN>switchName<SPAN class="punctuation token">,</SPAN> state<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="token function">require</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">"dojo/dom"</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">"dojo/dom-class"</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">"dojox/mobile/Switch"</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>dom<SPAN class="punctuation token">,</SPAN>domClass<SPAN class="punctuation token">,</SPAN>Switch<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN>switchName <SPAN class="operator token">+</SPAN> <SPAN class="string token">" -- "</SPAN> <SPAN class="operator token">+</SPAN> state<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>state <SPAN class="operator token">===</SPAN> <SPAN class="string token">"on"</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'app.showLoading()'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
app<SPAN class="punctuation token">.</SPAN><SPAN class="token function">showLoading</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN>
<SPAN class="comment token">//hide popup</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>state <SPAN class="operator token">===</SPAN> <SPAN class="string token">"off"</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
app<SPAN class="punctuation token">.</SPAN>map<SPAN class="punctuation token">.</SPAN>infoWindow<SPAN class="punctuation token">.</SPAN><SPAN class="token function">hide</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">switch</SPAN> <SPAN class="punctuation token">(</SPAN>switchName<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">case</SPAN> <SPAN class="string token">"redShuttleSwitch"</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="comment token">//Turn off All Active Shuttles if its currently toggled on</SPAN>
app<SPAN class="punctuation token">.</SPAN><SPAN class="token function">switchLogic</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">//Request Route</SPAN>
app<SPAN class="punctuation token">.</SPAN><SPAN class="token function">esriRouteRequest</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="number token">15</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">then</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN>routeResponse<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
app<SPAN class="punctuation token">.</SPAN><SPAN class="token function">routesGraphicFunction</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Red"</SPAN><SPAN class="punctuation token">,</SPAN> routeResponse<SPAN class="punctuation token">,</SPAN> app<SPAN class="punctuation token">.</SPAN>routesGraphicsLayer<SPAN class="punctuation token">,</SPAN> redRoute<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">//Display route </SPAN>
app<SPAN class="punctuation token">.</SPAN><SPAN class="token function">showGraphicsLayer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'routesGraphicsLayer'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">else</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="comment token">//when route gets toggled off, remove graphic from graphics layer </SPAN>
app<SPAN class="punctuation token">.</SPAN>routesGraphicsLayer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">remove</SPAN><SPAN class="punctuation token">(</SPAN>redRoute<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
app<SPAN class="punctuation token">.</SPAN>routesGraphicsLayer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">redraw</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">break</SPAN><SPAN class="punctuation token">;</SPAN>
app<SPAN class="punctuation token">.</SPAN>esriRouteRequest <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> routeRequest <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">esriRequest</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
url<SPAN class="punctuation token">:</SPAN> <SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=http%3A%2F%2Fwww.uofubus.com%2FServices%2FJSONPRelay.svc%2FGetRoutesForMapWithScheduleWithEncodedLine" target="_blank">http://www.uofubus.com/Services/JSONPRelay.svc/GetRoutesForMapWithScheduleWithEncodedLine</A><SPAN>"</SPAN></SPAN><SPAN class="punctuation token">,</SPAN>
content<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>
apikey<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"ride1791"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN>
handleAs<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"json"</SPAN><SPAN class="punctuation token">,</SPAN>
callbackParamName<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"method"</SPAN>
routeRequest<SPAN class="punctuation token">.</SPAN><SPAN class="token function">then</SPAN><SPAN class="punctuation token">(</SPAN>app<SPAN class="punctuation token">.</SPAN>routeRequestSucceeded<SPAN class="punctuation token">,</SPAN> app<SPAN class="punctuation token">.</SPAN>requestFailed<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">return</SPAN> routeRequest<SPAN class="punctuation token">;</SPAN>
app<SPAN class="punctuation token">.</SPAN>routeRequestSucceeded <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>data<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
routesArray <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">for</SPAN> <SPAN class="punctuation token">(</SPAN>i <SPAN class="operator token">=</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN> i <SPAN class="operator token"><</SPAN> data<SPAN class="punctuation token">.</SPAN>length<SPAN class="punctuation token">;</SPAN> i<SPAN class="operator token">++</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
routesArray<SPAN class="punctuation token">.</SPAN><SPAN class="token function">push</SPAN><SPAN class="punctuation token">(</SPAN>data<SPAN class="punctuation token">[</SPAN>i<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">return</SPAN> routesArray<SPAN class="punctuation token">;</SPAN>
app<SPAN class="punctuation token">.</SPAN>routesGraphicFunction <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN>colorDescription<SPAN class="punctuation token">,</SPAN> data<SPAN class="punctuation token">,</SPAN> graphicslayer<SPAN class="punctuation token">,</SPAN> routeGraphic<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> routeObjects <SPAN class="operator token">=</SPAN> data<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">for</SPAN> <SPAN class="punctuation token">(</SPAN>i <SPAN class="operator token">=</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN> i <SPAN class="operator token"><</SPAN> routeObjects<SPAN class="punctuation token">.</SPAN>length<SPAN class="punctuation token">;</SPAN> i<SPAN class="operator token">++</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>routeObjects<SPAN class="punctuation token">[</SPAN>i<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>Description <SPAN class="operator token">==</SPAN> colorDescription<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN>
<SPAN class="comment token">//Create Symbology</SPAN>
<SPAN class="keyword token">var</SPAN> routeSLS <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">SimpleLineSymbol</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">setStyle</SPAN><SPAN class="punctuation token">(</SPAN>SimpleLineSymbol<SPAN class="punctuation token">.</SPAN>STYLE_SOLID<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">setWidth</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="number token">4</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">setColor</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Color</SPAN><SPAN class="punctuation token">(</SPAN>routeObjects<SPAN class="punctuation token">[</SPAN>i<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>MapLineColor<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">//Create InfoTemplate</SPAN>
<SPAN class="keyword token">var</SPAN> routesInfoTemplate <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">InfoTemplate</SPAN> <SPAN class="punctuation token">(</SPAN>routeObjects<SPAN class="punctuation token">[</SPAN>i<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>Description<SPAN class="operator token">+</SPAN><SPAN class="string token">" Line"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"<b>Stops Schedule: </b>"</SPAN> <SPAN class="operator token">+</SPAN> app<SPAN class="punctuation token">.</SPAN><SPAN class="token function">moreInfoHyperlink</SPAN><SPAN class="punctuation token">(</SPAN>routeObjects<SPAN class="punctuation token">[</SPAN>i<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>StopTimesPDFLink<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token">//Create Graphic</SPAN>
routeGraphic <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Graphic</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Polyline</SPAN><SPAN class="punctuation token">(</SPAN>app<SPAN class="punctuation token">.</SPAN><SPAN class="token function">decodeGooglePolyline</SPAN><SPAN class="punctuation token">(</SPAN>routeObjects<SPAN class="punctuation token">[</SPAN>i<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>EncodedPolyline<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> app<SPAN class="punctuation token">.</SPAN>map<SPAN class="punctuation token">.</SPAN>SpatialReference<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> routeSLS<SPAN class="punctuation token">,</SPAN> routeObjects<SPAN class="punctuation token">[</SPAN>i<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>StopTimesPDFLink<SPAN class="punctuation token">,</SPAN> routesInfoTemplate<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">//Add graphics to graphics layer</SPAN>
graphicslayer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">add</SPAN><SPAN class="punctuation token">(</SPAN>routeGraphic<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
