Hi all,function getLocRes(results) {
//map.graphics.clear();
var symbol = new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([80, 0, 0]), 2), new dojo.Color([80, 0, 0, 0.5]));
var combinedExtent = new esri.geometry.Extent();
console.log("er",results.features.length);
for (var i = 0;i < results.features.length; i++) {console.log("i=",i);
var polyGraphic = new esri.Graphic(results.features, symbol);
console.log("i=",polyGraphic);
polyGraphic.setSymbol(symbol);
//map.graphics.add(graphic);
combinedExtent = esri.graphicsExtent(results.features);
map.setExtent(combinedExtent, true);
this function is working sort of but when I enable eithermap.graphics.clear();ormap.graphics.add(graphic);it stops where the code isconsole.log("i=",i);this showsonly 0 when map.graphics.add(graphic); is onif not it doesn't add graphic but shows console.log("i=",i); result until the endAm I missing something here that map.graphics.add(graphic); shouldn't work?dojo.require("dijit.layout.BorderContainer");
dojo.require("dijit.layout.ContentPane");
dojo.require("esri.map");
dojo.require("esri.dijit.Popup");
dojo.require("esri.dijit.Legend");
dojo.require("esri.layers.agsdynamic");
dojo.require("esri.layers.ArcGISTiledMapServiceLayer");
dojo.require("dijit.dijit");
dojo.require("esri.tasks.find");//search
dojo.require("esri.arcgis.utils");
dojo.require("esri.dijit.Print");
dojo.require("dojox.grid.DataGrid");
dojo.require("dojo.data.ItemFileReadStore");
dojo.require("dijit.form.Button");
dojo.require("esri.tasks.query");
dojo.require("esri.dijit.Scalebar");
dojo.require("esri.graphic");
dojo.require("esri.symbol");
