ArcSDE 9.3.1 SP1, ORACLE 11gHi, I seem to be struggling a bit with the proper sql syntax for the following task.table A = polygons of administrative boundariestable B = address pointsI need to update table B with the administrative area code (table A) of the area that contains the address point... also, it might happen, that one address point might fall into two (or even more) administrative areas, for me it's fine to take the first one the select command encounters.something like this doesn't work :
UPDATE ap x SET x.area_id = (SELECT a.area_id FROM zsj_za a, ap b WHERE (sde.st_intersects(a.shape, b.shape) = 1 AND abody.objectid = x.objectid AND rownum = 1)
returns the following error message : Error starting at line 1 in command:
UPDATE ab x SET x.zsj_id = (SELECT zsj.zsj_id FROM zsj_za zsj, ab abody WHERE (sde.st_intersects(zsj.shape, abody.shape) = 1 AND zsj.okres IN ('Martin') AND abody.objectid = x.objectid))
Error report:
SQL Error: ORA-29902: error in executing ODCIIndexStart() routine
ORA-06521: PL/SQL: Error mapping function
ORA-06522: Unable to load symbol from DLL
ORA-06512: at "SDE.ST_GEOMETRY_SHAPELIB_PKG", line 943
ORA-06512: at "SDE.SPX_UTIL", line 2623
ORA-06512: at "SDE.SPX_UTIL", line 2842
ORA-06512: at "SDE.ST_DOMAIN_METHODS", line 282
29902. 00000 - "error in executing ODCIIndexStart() routine"
*Cause: The execution of ODCIIndexStart routine caused an error.
*Action: Examine the error messages produced by the indextype code and
take appropriate action.
St_functions are running properly if I do pretty simple queries. I reckon it's the problem of the syntax 😉 obviously, I'm missing the concept of updating the table using the select command where the same table appears.... any ideas are more than welcome.thank you in advance for all your help
