Hello,I have a code that works in Arcgis 9.3 and I'm supposed to make it work in Arcgis 10.0. I'm new to Arcgis programming and to VBA, no answer will be too basic for me 🙂The code is :Set pElement = Nothing
pContainer.Reset
Set pElement = pContainer.Next
Do While Not pElement Is Nothing
 If pElement.Name = "Topo10" Then
   Dim pMapFrame As IMapFrame
   Set pMapFrame = pElement
   Exit Do
 End If
Loop
If pMapFrame Is Nothing Then
 MsgBox "BUG with mapFrame"
 Exit Sub
End If
Dim pMap As IMap
Set pMap = pMapFrame.Map
Set pMap.SpatialReference = OpenLambertSpatialRef
pMap.AddLayer OpenLayerFile(TOP10PATH, "TOP10.lyr")
pMapFrame.ExtentType = esriExtentBounds       'clears pMapFrame.MapBounds
pMapFrame.MapScale = 10000
Dim pEnvelope As IEnvelope
Set pEnvelope = pMapFrame.MapBounds
The problem comes at the line in bold (pMapFrame.ExtentType = esriExtentBounds). After this line, pMapFrame.MapBounds becomes Nothing, so I can't copy it in pEnvelope (this worked in 9.3). If I remove the line in bold then it works, but the result isn't at the good coordinates.Any idea why it happens ? Or do you know another way I could do this ?Any answer is appreciated,acangi
