I have to create a four pane map layout, showing progression of a project through four years. I created one pane the way I wanted them all to look, and copied it. I then pasted it and moved the copy to a free area in the layout.
I then tried to turn on another layer within the map element that I just pasted. I selected the map element (activated the map frame) and the layer appeared, but it also appeared in the first map element I copied from. It is like the two map frames are linked.
Is there a way to turn this off?
--Adam
