I have a point shapefile feature class which has over 500,000 points (locations of houses) and another point shapefile feature class which has about 30 points (locations of shops). Is it possible to be able to calculate the distance between each house and the closest shop? Ideally i would quite like a file which then contains all the distances between the house and the nearest shop which can then be shown as a histogram so i can analyse the distribution of distances from each house to the nearest shop?
Is there an easy way to do this or is there too many points for this to be possible?
Thanks for your help,
Katy
