I downloaded a webapp builder template (javascript) that I've placed on my own web server and is running fine. However, I am not able to modify the widgets in the config.json file to the settings that I want. For instance, I want the "Coordinate" widget to have meters instead of feet, however, when I adjust the config.json file in the widget file, these changes aren't reflect. Has anyone encountered this issue? I may be doing it all wrong so if someone can point me in the right direction, that would be much appreciated. I read the webapp builder documentation (http://doc.arcgis.com/en/web-appbuilder/extend-apps/coordinate.htm) but can't seem to figure it out.
This is the json in the current config file (for the app itself, not just the widget):
<SPAN class="pln" style="color: #000000;"> </SPAN><SPAN class="pun" style="color: #145680;">{</SPAN><SPAN class="pln" style="color: #000000;"> </SPAN><SPAN class="str" style="color: #800000;">"label"</SPAN><SPAN class="pun" style="color: #145680;">:</SPAN><SPAN class="pln" style="color: #000000;"> </SPAN><SPAN class="str" style="color: #800000;">"Coordinate"</SPAN><SPAN class="pun" style="color: #145680;">,</SPAN><SPAN class="pln" style="color: #000000;"> </SPAN><SPAN class="str" style="color: #800000;">"uri"</SPAN><SPAN class="pun" style="color: #145680;">:</SPAN><SPAN class="pln" style="color: #000000;"> </SPAN><SPAN class="str" style="color: #800000;">"widgets/Coordinate/Widget"</SPAN><SPAN class="pun" style="color: #145680;">,</SPAN><SPAN class="pln" style="color: #000000;"> </SPAN><SPAN class="str" style="color: #800000;">"position"</SPAN><SPAN class="pun" style="color: #145680;">:</SPAN><SPAN class="pln" style="color: #000000;"> </SPAN><SPAN class="pun" style="color: #145680;">{</SPAN><SPAN class="pln" style="color: #000000;"> </SPAN><SPAN class="str" style="color: #800000;">"left"</SPAN><SPAN class="pun" style="color: #145680;">:</SPAN><SPAN class="pln" style="color: #000000;"> </SPAN><SPAN class="lit" style="color: #953838;">200</SPAN><SPAN class="pun" style="color: #145680;">,</SPAN><SPAN class="pln" style="color: #000000;"> </SPAN><SPAN class="str" style="color: #800000;">"bottom"</SPAN><SPAN class="pun" style="color: #145680;">:</SPAN><SPAN class="pln" style="color: #000000;"> </SPAN><SPAN class="lit" style="color: #953838;">20</SPAN><SPAN class="pln" style="color: #000000;"> </SPAN><SPAN class="pun" style="color: #145680;">},</SPAN><SPAN class="pln" style="color: #000000;"> </SPAN><SPAN class="str" style="color: #800000;">"config"</SPAN><SPAN class="pun" style="color: #145680;">:</SPAN><SPAN class="pln" style="color: #000000;"> </SPAN><SPAN class="pun" style="color: #145680;">{}</SPAN><SPAN class="pln" style="color: #000000;"> </SPAN><SPAN class="pun" style="color: #145680;">}</SPAN>This is the json in the widget config file:
<SPAN class="pun" style="color: #145680;">{</SPAN><SPAN class="pln" style="color: #000000;"> </SPAN><SPAN class="str" style="color: #800000;">"outputunit"</SPAN><SPAN class="pun" style="color: #145680;">:</SPAN><SPAN class="pln" style="color: #000000;"> </SPAN><SPAN class="str" style="color: #800000;">"dms"</SPAN><SPAN class="pun" style="color: #145680;">,</SPAN><SPAN class="pln" style="color: #000000;"> </SPAN><SPAN class="str" style="color: #800000;">"spatialReferences"</SPAN><SPAN class="pun" style="color: #145680;">:</SPAN><SPAN class="pln" style="color: #000000;"> </SPAN><SPAN class="pun" style="color: #145680;">[]</SPAN><SPAN class="pln" style="color: #000000;"> </SPAN><SPAN class="pun" style="color: #145680;">}</SPAN>The latter says DMS but the units still show up as feet.
Anyway, any help would be appreciated.
Thank you
