Greetings,
I am trying to use the directions widget in JSAPI 4.7 with our own route service, but when doing this the widget won't load. I realize that this widget is still in beta, but I am wondering if I am missing something in the configuration setup or maybe my ArcGIS Server, needs to be a certain version for this to work. Here is the simple code I am using:
<SPAN class="keyword token">var</SPAN> dirWidget <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Directions</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
view<SPAN class="punctuation token">:</SPAN> view<SPAN class="punctuation token">,</SPAN>
routeServiceUrl<SPAN class="punctuation token">:</SPAN> <SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2F" target="_blank">https://</A><SPAN><<link to working route service>>"</SPAN></SPAN><SPAN class="punctuation token">,</SPAN>
container<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"directionsDiv"</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>The result is:
Thanks very much for any feedback!
Regard,
Tom
