I have a bit of an odd question. I currently have a point dataset that has been randomly generated over a land base. I want to create a set of polygons at said points, corresponding to an area field, where each polygon will be 1, 2, 3 or 4 hectares in size (this is done in a random fashion). I am able to achieve this by either using the buffer tool or by using the table to ellipse tool (where I need the major and minor axis), and simply adding a field within my point features which determines which size the polygon will be, and then creating an if statement that builds the size of the buffer/table to ellipse based on this...
My question is, I am looking to find a way to generate polygons at these points that are not perfectly circular or an ellipse. I have a set of 4 pre-drawn polygon shapes (oblong/uneven shapes that are not exactly buffers/ellipse) which I would like to map at the same location of these points. Again, these polygons would be randomly set to each point, with a random designation of 1,2,3, or 4 hectares.
I have 100s-1000s of points, so I would like to automate this, but I have not found anything that would be appropriate for this problem (other than a simple buffer or table to ellipse). I figure it would be some sort of copy operation, where a polygon is copied from a template, and then built at the point, but I'm not sure how to accomplish this.
Again, a fairly odd problem, but I just want to cover my bases by asking the net.
Thanks in advance!
