Hello Everyone,
Given below are my scenario
Query the service Url with object id then if it contains any attachment then display it and facilitate the user to add attachments.
I have referred the samples and found the Edit attachment. But in that it has been done through ListenableFuture<IdentifyLayerResult>. But instead I want to do it with ListenableFuture<FeatureQueryResult>
Everything fine till the query and getting result. After getting result and iterating through next. I am getting result as feature and could not find any method to convert from com.esri.arcgisruntime.data.Feature to com.esri.arcgisruntime.data.ArcGISFeature. Please suggest me on this.
Given below Code Snap
private void QueryFeatureandLoad()
mServiceFeatureTable = new ServiceFeatureTable(getString(R.string.sample_service_url));
mServiceFeatureTable.setFeatureRequestMode(ServiceFeatureTable.FeatureRequestMode.ON_INTERACTION_CACHE);
// create the feature layer using the service feature table
mFeatureLayer = new FeatureLayer(mServiceFeatureTable);
// clear any previous selection
mFeatureLayer.clearSelection();
mSelectedArcGISFeature = null;
final QueryParameters query = new QueryParameters();
final String searchString ="objectid=77";
//make search case insensitive
query.setWhereClause(searchString);
final ListenableFuture<FeatureQueryResult> future = mServiceFeatureTable.queryFeaturesAsync(query, ServiceFeatureTable.QueryFeatureFields.LOAD_ALL);
// add done loading listener to fire when the selection returns
future.addDoneListener(new Runnable() {
@Override
public void run() {
try {
// call get on the future to get the result
FeatureQueryResult result = future.get();
// check there are some results
if (result.iterator().hasNext()) {
// get the extend of the first feature in the result to zoom to
Feature feature = result.iterator().next();
Envelope envelope = feature.getGeometry().getExtent();
mMapView.setViewpointGeometryAsync(envelope, 10);
//Select the feature
mFeatureLayer.selectFeature(feature);
GOT STUCKUP HERE * mselectedArcGISFeature is ArcGISFeature ---- How to Convert Feature to ArcGISFeature
mAttributeID = mSelectedArcGISFeature.getAttributes().get("objectid").toString();
// get the number of attachments
final ListenableFuture<List<Attachment>> attachmentResults = mSelectedArcGISFeature.fetchAttachmentsAsync();
attachmentResults.addDoneListener(new Runnable() {
@Override
public void run() {
try {
attachments = attachmentResults.get();
Log.d("number of attachments :", attachments.size() + "");
// show callout with the value for the attribute "typdamage" of the selected feature
mSelectedArcGISFeatureAttributeValue = (String) mSelectedArcGISFeature.getAttributes().get("typdamage");
if (progressDialog.isShowing()) {
progressDialog.dismiss();
showCallout(mSelectedArcGISFeatureAttributeValue, attachments.size(),mapPoint);
Toast.makeText(MainActivity.this, getApplication().getString(R.string.info_button_message), Toast.LENGTH_SHORT).show();
} catch (Exception e) {
Log.e(TAG, e.getMessage());
} else {
Toast.makeText(MainActivity.this, "No states found with name: " + searchString, Toast.LENGTH_SHORT).show();
Toast.makeText(MainActivity.this, "Feature search failed for: " + searchString + ". Error=" + e.getMessage(),
Log.e(getResources().getString(R.string.app_name),
"Feature search failed for: " + searchString + ". Error=" + e.getMessage());
