Hello folks.
In Arc Map 10.1 I have I polyline with distances (2.659542 m) and length (0.00266 km) fields. Those fields were calculated with geomtric calculator.
I am tryin a Multiple Ring Buffer Tool with 30, 50 and 100 metres of distance. At the end, the tool shows 3 rings, however,
2.5 Km polyline is located within the 30 metres ring (see littel blue polyline in inner ring). I am really confused. Why 30 metres ring is larger than polyline length?
The polyline is in WGS 1984 World Mercator.
Can you give an idea(s) to fix this problem?
