I get the following error:
com.esri.arcgis.android.samples.wmslayer W/System.err﹕ java.lang.NumberFormatException: Invalid int: "WGS84(DD)"
I am adding a custom WMS server like this:
String wmsURL = "http://<lan ip>:8080/geoserver/wms";
wmsLayer = new WMSLayer(wmsURL, SpatialReference.create(32633));
I have debugged and decompiled the source and it is "class g" that is the problem, the array "t" which contains all the reference systems in the EPSG: range does Integer.parseInt(var2.substring(5)); ,but the "EPSG:WGS84(DD)" cannot be parsed like this and it throws the NumberFormatException and my layer will never be created.
This was testet with the WmsLayer sample code with version 'com.esri.arcgis.android:arcgis-android:10.2.6-2'
