Hi everyone,
I'm using ArcGis 10.3. I am on the model builder and I have a While iteration. What I want to do is to create a counter: a variable x which is initialized with the value 1 and add +1 at every run, so the variable x actually shows the number of run.
This is because I want to use that value for saving data with in-line substitution (...%x%...).
You can see attached my first attempt. Basically my Continue is a precondition for Calculate value (2) and the code in it is:
Expression: x("%Continue%")def x(n):
if n== "true":
x=x+1
but I got this error:
ERROR 000539: Error running expression: counter("true")
File "<expression>", line 1, in <module>
File "<string>", line 3, in counter
UnboundLocalError: local variable 'counter' referenced before assignment
Is there a nicest and easiest way to create a counter?
(Basically the For iteration has it automatically as the Value, but the While lacked of a variable which takes account of the run)
Alessandro
