I am trying to delete some records from a feature layer, but I kept getting the error of invalid parameters from the errback.Below is my code:function deleteRecords()
var incidentId = 2;
var queryTaskDeleteRecords= new esri.tasks.QueryTask(FEATURE_SERVER+"/"+LAYER_V_RECORDS);
var queryDeleteRecords = new esri.tasks.Query();
queryDeleteRecords.outSpatialReference = map.spatialReference;
queryDeleteRecords.returnGeometry = true;
queryDeleteRecords.outFields = ["*"];
queryDeleteRecords.where = FIELD_V_RECORDS_INCIDENTID + " = " + incidentId ;
queryTaskDeleteRecords.execute(queryValveRec,deleteRecordsResults);
function deleteRecordsResults(results)
var graphicArray = [];
var valve_suggest_new = new esri.layers.FeatureLayer( FEATURE_SERVER+"/"+LAYER_V_RECORDS,{
outFields:["*"]
for (var i = 0; i < results.features.length; i++)
var attributes = {};
attributes[FIELD_V_RECORDS_OBJECTID] = results.features.attributes[FIELD_V_RECORDS_OBJECTID];
var graphic = new esri.Graphic(results.features.geometry, null, attributes);
graphicArray.push(graphic);
alert("graphicArray : " + JSON.stringify(graphicArray));
valve_suggest_new.applyEdits(null, null, graphicArray, function onComplete(adds, updates, deletes)
if (deletes.length > 0)
alert("deletes : " + JSON.stringify(deletes));
function errCallback(err)
alert(err);
Is my declaration of the graphic array wrong? I did try deleting it graphic by graphic but it still doesn't work.
