I am importing X,Y values from file into a shape, but I need to keep the labels of each point as well in my application.
By lack of a way to keep a list of texts, I create a long string, separated by tabs, to keep the labels and the shape in the same feature in the resulting table.
I use the following code
cursor = arcpy.da.InsertCursor("Pipes", ["Name", "SHAPE@", "PointLabels"])
cursor.insertRow([fileName, polyline, pointLabels])
For some datasets, I get this error
The row contains a bad value. [PointLabels]
I assume that this is caused by exceeding some size limit, but I cannot determine easily which size this could be. (number of points and length of text labels vary quite a lot).
Any idea if there is a limit, and if so, what is this limit ?
