I have the following code and i am getting an error on line 76 with the arcpy.da.UpdateCursor that update feature attributes to proper case . I am unsure why. I would really appreciate some help please?
Thanks.
# Import arcpy module
import arcpy
from arcpy import env
# Allow overwrite
# Script user input parameters
polygonLayer = "TaxParcels1" #Taxparcels
pointLayer = "CCAP8" #Point Layer
arcpy.env.workspace = r"Database Servers\15_SQLEXPRESS.gds\CCAPTEST (VERSION:dbo.DEFAULT)" #arcpy.env.workspace = r"Database Servers\15_SQLEXPRESS.gds\TEST (VERSION:dbo.DEFAULT)"
poly = "ACCOUNT_1"
Pnt = "Account"
sjpoints = "In_memory\sjpoints"
parcelsCount = int(arcpy.GetCount_management(pointLayer).getOutput(0))
dsc = arcpy.Describe(pointLayer)
selection_set = dsc.FIDSet
if len(selection_set) == 0:
print "There are no features selected"
elif parcelsCount >= 1:
#Run the Spatial Join tool, using the defaults for the join operation and join type
arcpy.SpatialJoin_analysis(pointLayer, polygonLayer, sjpoints)
# define the field list from the spatial join
sourceFieldsList = ["TARGET_FID", poly,"SiteAddress",'SiteNum_1', 'SiteStreet_1','SiteNumSfx_1','Predir_1','SiteStreet_1','Postdir_1', 'SiteCity_1', 'SiteZIP_1', 'OwnerName_1', 'StreetType_1'] #,'StreetType_1'
# define the field list to the original points
updateFieldsList = ["OID@", Pnt,"SiteAddres", 'SiteNum', 'StreetName','SiteNumSfx','Predir','SiteStreet', 'Postdir', 'SiteCity', 'SiteZip', 'OwnerName', 'StreetType'] #, 'StreetType'
# Start an edit session. Must provide the workspace.
edit = arcpy.da.Editor(arcpy.env.workspace)
# Edit session is started without an undo/redo stack for versioned data
# (for second argument, use False for unversioned data)
edit.startEditing(True)
# Start an edit operation
edit.startOperation()
manualFields = ["FacltyType","GIS_STEW", "StructType", "Verified", "Status", "StructCat", "APA_CODE",'StreetName'] #,'StreetName'
with arcpy.da.UpdateCursor(pointLayer, manualFields) as rows:
for row in rows:
row[0] = ("Single Family Home")
row[1] = ("Canyon")
row[2] = ("Primary, Private")
row[3] = ("Yes, GRM, TA")
row[4] = ("Active")
row[5] = ("Residential")
row[6] = ("1110")
row[7] = (sourceFieldsList[4] + " " + sourceFieldsList[12])
rows.updateRow(row)
del row
del rows
# populate the dictionary from the polygon
valueDict = {r[0]:(r[1:]) for r in arcpy.da.SearchCursor(sjpoints, sourceFieldsList)}
with arcpy.da.UpdateCursor(pointLayer, updateFieldsList) as updateRows:
for updateRow in updateRows:
keyValue = updateRow[0]
if keyValue in valueDict:
for n in range (1,len(sourceFieldsList)):
updateRow = valueDict[keyValue][n-1]
updateRows.updateRow(updateRow)
del updateRows
del updateRow
#Update feature attributes to proper case
fields1 = ["StreetName", "SiteStreet","SiteAddres","OwnerName","StreetType"]#,'StreetType'
with arcpy.da.UpdateCursor(pointLayer, fields1) as cursor:
for row in cursor:
row[0] = row[0].title()
row[1] = row[1].title()
row[2] = row[2].title()
row[3] = row[3].title()
row[4] = row[4].title()
cursor.updateRow(row)
# Stop the edit operation.
#edit.stopOperation()
# Stop the edit session and save the changes
edit.stopEditing(True)
arcpy.RefreshActiveView()
#arcpy.Delete_management(sjpoints)
