Good Afternoon,I am running across an issue with using the geoprocessor with Erase. I have used this style (below) many times, and with commands that require much more complex arguments. I can't see what I'm doing wrong. Any help or suggestions appreciated. Set pGP = CreateObject("esriGeoprocessing.GpDispatch.1") pGP.OverwriteOutput = 1 If fso.FolderExists("C:\Program Files\ArcGIS") Then pGP.Toolbox = "C:\Program Files\ArcGIS\ArcToolbox\Toolboxes\Analysis Tools.tbx" Else pGP.Toolbox = "C:\Program Files(x86)\ArcGIS\ArcToolbox\Toolboxes\Analysis Tools.tbx" End If MsgBox "subErase - (In, Erase, Out) = " & vbNewLine & sInputLayer & vbNewLine & sEraseLayer & vbNewLine & sOutputLayer pGP.Erase_Analyses sInputLayer, sEraseLayer, sOutputLayer Set pGP = Nothing It is failing at the call to the command. The msgbox shows that all three variables are set to valid paths. I ran the command in the command line interface, and no problem.I'm testing on Win7 64, ArcGIS 9.3.1, ArcINFO license.Thanks in advance for any assistance.Take care,Craig
