So I have the inverse of this problem: How do I remove holes (such as lakes) from a polygon feature
I have a country polygon shp with holes for where the lakes should be. I also have a separate polygon shapefile for the lakes, which was done during a dry year so the edges (perimeter) do not match the 'holes' in the country ADM level file.
How do I add the lake information into the holes? Is it possible to use those voids as the perimeter of the lake polygons? If so, how?
I have tried merging, union, autocomplete polygon and I get a mess with either gaps, or multiple sub polygons (with teeny polygons where the boundaries cross each other).
I have almost 200 lakes I need to incorporate into the larger file, and I am using ArcMap 10.5.1.
Any help/tricks/tips will be greatly appreciated. Thank you
#Geoprocessing #createfeature #merge #union #newbie
