I'm using the the JavaScript API v4.14. I have a stack of GraphicsLayers on my map that can be toggled on and off by the user (I'm just using map.add() and map.remove() to toggle). One layer in particular should always be positioned below the others. However, if it's toggled off and back on again, it gets positioned above the other layers. I have been able get around this by removing all the layers during the toggle and re-adding them to ensure they go in the right order. However, it seems awkward to have to this every time a user performs a toggle function as I have a lot of layers. Is there some way to ensure that this particular layer is always below the others without having to figure our which layers are being displayed and then sorting them appropriately? I've tried using the map.reorder() method without any luck.
