I can't figure out why i am getting an empty feature class after i delete features, add field and calulate and delete empty features. I would appreciate some help.
Taxparcels = "C:/Temp/Scratchworkspace.gdb/TaxParcels1"
PT = "Taxparce1s"
arcpy.MakeFeatureLayer_management(Taxparcels, PT)
# Process: Select Layer By Attribute to remove Q accounts
arcpy.SelectLayerByAttribute_management(PT, "NEW_SELECTION", "\"PIN\" LIKE 'Q%'")
# Process: Delete Features
if int(arcpy.GetCount_management(PT).getOutput(0)) > 0:
arcpy.DeleteFeatures_management(PT)
#arcpy.DeleteField_management(PT, ["ACRES"])
PT1 = "Taxparcels1"
arcpy.MakeFeatureLayer_management(PT, PT1)
arcpy.FeatureClassToFeatureClass_conversion(PT1, "C:\Temp\Scratchworkspace.gdb", "TEST")<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
